Emission
STaG
Emission
Příspěvek od STaG »
Hi everybody,
I have a 1991 Subaru E12 - Sdx and its last emission tests are like that. what is your idea that CO being high for high rpm.
1. Test (Idle )
CO % : 0.47
CO2 % : 14.3
HC ppm : 87
O2 % : 0.60
LAMBDA : 1.01
2. Test (high rpm almost 3000)
CO % : 1.04
CO2 % : 14.1
HC ppm : 43
O2 % : 0.34
LAMBDA : 0.98
1991 E12 SDX 4WD Sunroof
Re: Emission
1. check air filter element !
STaG
Re: Emission
Příspěvek od STaG »
* The air filter was new.
* Do you know what is the my car tune up and emission values ?
Idle speed : ?
Ignition timing : ?
CO% at Idle Speed : ?
HC% at Idle Speed : ?
